a95x f3 cant turnn it on cant flash it
last update
[21:21:22 708][HUB1-1][Inf]-------------Download system.PARTITION-----------
[21:21:22 708][HUB1-1][Inf]--0-7-0-16
[21:21:22 708][HUB1-1][Inf]--download store system sparse 1377898716
[21:21:22 708][HUB1-1][Inf]--Send download command success
[21:21:22 723][HUB1-1][Inf]--Read command status success
[21:23:44 401][HUB1-1][Err]--usbReadFile read 0 time failed, actlen=-116, return[]
[21:23:44 401][HUB1-1][Err]--Download file failed, sequence 2426
[21:23:44 401][HUB1-1][Inf]--Failure : 1, FailureMax : 3
[21:24:44 928][HUB1-1][Err]--Write 38816 media command failed
[21:24:44 928][HUB1-1][Err]--Download file failed, sequence 2426
[21:24:44 928][HUB1-1][Inf]--Failure : 2, FailureMax : 3
[21:25:45 450][HUB1-1][Err]--Write 38816 media command failed
[21:25:45 450][HUB1-1][Err]--Download file failed, sequence 2426
[21:25:45 450][HUB1-1][Inf]--Failure : 3, FailureMax : 3
[21:25:45 512][HUB1-1][Err]--[0x30403003]UBOOT/Partition system/Download buffer/Data tranfer error
[21:25:45 512][HUB1-1][Inf]--Close device handle 0x0000067c
Originally posted by kenduvernay View PostDoes anyone know how to kill the audio in that nasty boot animation?
I have problem with my tv box i cant turn it on after tunit off... i need to rexonnect cable many times till it turns on
1) Aprire il file build.prop che si trova su: \ system,aggiungi sul file la linea debug.sf.nobootanimation = 1 Non dimenticare di cliccare "salva"
Originally posted by geneshys View Post
> Togliere l'Animazione iniziale
No problems I just remaned the zip to zip.bak. Now it boots to the A95 graphic followed by the Google Graphic. Boots faster and don't have to hear or see that nasty animaion.
I also need to remove the annoying sound and want it to boot faster
There are currently 1459 users online. 0 members and 1459 guests.
