Highlights as found
Amlogic S905X3
Amlogic S905X3 applies quad-core Cortex-A55 processors, which is described as an "advanced application processor designed for hybrid OTT/ IP Set-Top Box (STB) and high-end media box applications. The Cortex-A55 cores deliver up to twice the performance compared to Cortex-A53 in memory benchmarks, and a more typical 20 to 30% performance improvement for common tasks at the same frequency.
Android 9.0 OS
It is based on the latest Android 9.0 OS, with high speed and smooth performance, which is designed to turn your regular TV into a smart one.
8K UHD Resolution
True 8k picture resolution can be as high as 7680*4320 to achieve 16 times of 1080p picture accuracy.
OTA (over-the-air) Updates
When your device gets an update, you will be the first who knows about this. Just stay connected and the system will install it automatically.
2.4G/5G Dual Band WiFi
With support for 2.4Ghz and 5Ghz band, it can transmit higher amounts of data.
Geekbuying
