Flash tool won't recognize my MK809 III
    Hello everybody!
    Yesterday I got my MK809 III I ordered from ****, and as with every other Android device I've had I just have to flash a new rom to it.. It's a habbit..
    Anyways, I've got the device to boot in to flash mode so that my comp detects it and I've installed the drivers that came with the tool. Everything good so far.
    But when I start the flash tool it keeps saying "No found RKAndroid rock usb".
    I've tried to boot it before I start the tool and after I've started it, but nothing seem to work.
    Anyone have any idea what I might be doing wrong?
    Here are some images of my device:
ID:	438702Click image for larger version
ID:	438703Click image for larger version
ID:	438700Click image for larger version
    Regards
    Originally posted by DeepSilence View Post
    Hello everybody!
    [ATTACH=CONFIG]3618[/ATTACH][ATTACH=CONFIG]3619[/ATTACH][ATTACH=CONFIG]3616[/ATTACH][ATTACH=CONFIG]3617[/ATTACH]
    Regards
    did you tried to use the connect to pc option?
    then rebbot to flash mode.
    I have two of those and thats what I did.
    Connect to power and otg (I know its strange but it was the only way it worked for me)
    Otg to pc
    Power to power
    Good luck
      Otg to pc
      Power to power
      Good luck
      Are you using windows 8.1 (windows 8?) If so due to the USB stack rewrite, the flash tool does not work. Try Win 7 or below
        have a read on
        and
        have a read on my reply: write-tome
          try to open the option file for the flash tool and enable usb1.1
          Hello everybody!
          Regards
