I have a new MX10 Android Box.It has 4 GB RAM and 32 GB Storage, Android 9.0. The board is stamped:
MXQ RK3328 D4_A
Version 2.0 Date: 20181219
Design from Hugson
I was trying to get full root on this box and ended up bricking it (surprise) I was able to flash firmware for the H96 Max Plus on this box and get it working, however the WiFi no longer works. If anyone can point me to the right firmware i would be very grateful.
I should also say that this box is working well now and does have full root access. So I would be happy if someone could tell me how to get the WiFi working. Ethernet works great. The WiFi just won't start.
Ok, just loaded the hk1 max rk3318 Android 9 ROM on this box. Again everything is working fine but the WiFi. It appears the only ROM's this box will load has "loader version 2.50". All the actual MX10 ROM's I can find have loader version 2.49 or below and will not load. Any suggestions?
I've now had the box apart multiple times to put it into Maskrom Mode to flash different roms. So far it has accepted the following roms:
A95XR3-RK3328
N5NOVA_3318-9.0-MGCTV15020190912
RK3318_DC_R1_MAX_HS2734A_9_20191029.1026
RK3318_DC_R1_PLUS_HS2734_9_20190917.0427
RK3328_DC_HK1_Max_circle_SSV6051_RTL8189_9_2019052 3.1830
x88pro_rk3318_d4_9.0_ssv6256_x88pro_20190705_r1 (this one will even light up the blue light)
The Android (.0 Roms for the H96 Max Plus and the H96 Max
All of the above ROMs will flash, but not one of them will give me WiFi. I can't find a single ROM made for the MX10 that will flash successfully. I find this to be really odd. The Network chip appears to be "SV605IP" Any ideas would be greatly appreciated.
I have tha same problem.
My MX10 box is labeled in pcb board as R328Q84KDX_V3.0 2019.07.12 and i noticed tha the chip is RK3318 and the wifi is SV6051P.
i can't find any working firmware. I tested some other firmwares but i had no wifi.
Can anyone help?
I have another one that is untouched and is working. I tried to dump the firmware and flash the bricked one with no luck.
Please HELP!
