mk808b I need a brutally overclocked kernel
Originally posted by mo123 View PostHere is the first overclocked MK808B kernels.
Android 4.1.1, 720p, 3.0.8 kernels
You also have to flash boot.img to run GPU higher than 400 Mhz.
Highest overclocked kernel is - CPU 1608 Mhz, GPU 533 Mhz & DDR 1066 Mhz.
Use these at your own risk with proper cooling.
Keep the good work!
Originally posted by zoliaz1993 View Post[ATTACH=CONFIG]3612[/ATTACH][ATTACH=CONFIG]3613[/ATTACH][ATTACH=CONFIG]3614[/ATTACH][ATTACH=CONFIG]3615[/ATTACH]
I used a 1.6GHz kernel. Remains stable and does not heat up.
I want to set up the clock frequency. How?
(Sorry for my bad English)
)you seem to put an heatsink on the top of the case ?? it must habitually be directly on the cpu with a thermal paste. this way you will probably 'brutaly' fry your stick even with a stock firmware cuz heat can't go out anymore. you better unplug your stick when you go out home, when you return don't ask why the roof is in fire
Originally posted by malfrat View Postyou seem to put an heatsink on the top of the case ?? it must habitually be directly on the cpu with a thermal paste. this way you will probably 'brutaly' fry your stick even with a stock firmware cuz heat can't go out anymore. you better unplug your stick when you go out home, when you return don't ask why the roof is in fire
Thermal Pad is below.
There are currently 2778 users online. 1 members and 2777 guests.
