tronsmart t428 bluetooth problem
    I have moga pro controller
    Then i use it to game on my tv
    Is lost connection to my tv stick
    tronsmart t428
    I run latest firmware form
    Tronsmart is a leading brand innovating cutting-edge audio products such as speakers & headphones with premium sound quality.
    i too had problems with the stock rom ,i think everyone had.....
    try another one eg. http://www.freaktab.com/showthread.p...2-by-lewy20041
    or finless or from strauso. just go a few threads up or down you will find them all!
    fwiw, the more recent one is the one in the link.
      Is seen to be a small bluetooth is the problem
      I have moved it form back of my tv to the side, so my controller can see the device (Line sight)
      Works mutch better
      But i wish the device have a stronger antenna
        Works mutch better
        again,try another firmware and your worries are (almost) over!!!
          So is just the firmware?
            yes!
              yes!
              Try another firmware
                I have try finless rom
                Bluetooth works better, but not so strong i have hope
                But thanks for you help
