Question about using twrp
Is it possible to flash stock rom using twrp instead of USB burning tool? I'm using a ROM that makes my reset button not work and I can boot into twrp thanks to an app, but can't connect to my computer with the USB burning tool. Would hate having to open it up to do rom mask modeTags: None
It was here on Freaktab
Hi there guys and girls, one more rom/fw for you all! Many thks to Khadas for sending me the device to play And many thks to trebor for be my beta tester ;) Ok guys im going to write the max i remember i did on sdk... i can't remember all of it! Build from Latest source. Debug Build ( i might do in the future a rls build with
There are currently 4555 users online. 0 members and 4555 guests.
