[ROM] SC v1.0 USER/USERDEBUG - GTKing SN: 922X - "Normal" Build - 20200225
    DISCLAIMER: MY ROMs(WORK) CAN NOT BUT USED FOR ANY COMMERCIAL PROJECTS WITHOUT MY CONSENT.
    Anyway, one more rom/fw for you all!
    And many thks to trebor for be my beta tester
    Build from Latest source, all changes done in source itself...
    Btw from now on i'm going to be very "economical" about my changelogs...
    THIS BUILD IS FOR SN: 922X (First Gen GTKing)
    Differences of USER and USERDEBUG builds:
    User Build: This build is done to be as close to a company rls as possible, it does not have root or twrp and is compiled with rls keys and SELINUX enforced, what this means for you?
    Well it means lot more apps show in Playstore that didn't show before, (EX: my isp androidtv live tv app, only shows in Playstore non rooted and SELINUX enforced devices, also the streams in the app does not even play in rooted devices.). Like this there's lots of other ISP/NON ISP apps Out there....
    UserDebug Build: This build does have root, twrp, selinux is permissive and some other stuff you will see in changelog down there.., but of course you will lose the above...
    FIRST BOOT WILL TAKE SOME TIME, SO JUST WAIT UNTIL IT SHOWS THE LAUNCHER........
    CHOOSE YOUR VENNON........
    Changelog v1.0:
    • Build from latest AML Pie SDK
    • Fixed the annoying random waking up from sleep or shutdown.
    • Added bluetooth to side settings.
    • Dolby Atmos HW decode support (NOT HD)
    • Reboot to TWRP or Switch OS ( Only on UserDebug build )
    • Added small delay on google assistant, so on default remote you need to keep the button pressed to work, single press does not work.
    • (Cont. from above) i did it like this since this remote need you to keep the MIC button pressed for listening you.
    • Gone back to "basic" on "Normal" build, if you do not notice it... then you do not need to know anyway lol...
    • And lots of other stuff...
    Bugs:
    • Of course there is bugs!! there always be bugs!!
    Want to buy me a beer?
    Download:
    Install instructions:
    • Use usb burning tool v2.2.0 to burn the IMG.
    THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
    USE AT YOUR OWN RISK!
    Enjoy it!
    Thank you Superceleron
    • superceleron
      superceleron commented
      Editing a comment
      You welcome
