Google’s Android operating system may be designed for smartphones, tablets, and TVs. But the folks at the Android-x86 project have been packaging up the open source version this mobile OS and turning it into a desktop operating system for years.
Today the latest stable release is out — Android-x86 9.0 is designed to let you run Android 9 Pie on a desktop, laptop, or tablet with an Intel or AMD processor.
In addition to bringing Android 9 features including updated apps, APIs, and UI elements, this PC-based build includes:
- Support for 32-bit and 64-bit x86 processors
- Hardware-accelerated graphics with support for OpenGL ES 3.x on Intel, AMD, and NVIDIA GPUs, as well as experimental Vulkan graphics support
- An optional Taskbar launcher (although you can use a stock Android-style launcher as well)
Supported hardware includes WiFi, Bluetooth, Ethernet, camera, audio, and multitouch input.
You can install the operating system like any GNU/Linux distribution — or even run it as a LiveCD, which lets you boot into Android without installing it. I took the operating system for a brief spin in VirtualBox today to grab the screenshot above — but I did have to follow the instructions in the Android-x86 documentation in order to boot a live image in a virtual machine.
While Android-x86 development tends to lag behind Google’s release schedule by a year or two (Android 11 is already coming this year), the latest stable release of this Android-for-PC operating system comes just a little more than a year after the first stable release of Android-x86 8.1.
But if you’re itching to run Android 10 on a PC, there are options. Bliss OS 12 is an Android 10-based operating system for PCs with x86 chips, and after releasing alpha builds a few months ago, the developers of Bliss OS have moved the latest builds to beta status.
Source: https://liliputing.com/2020/02/run-a...d-x86-9-0.html
