Anyway, one more rom/fw for you all!
And many thks to trebor for be my beta tester
This rom is as "TRUE" to AndroidTV as possible, no other mambo jambo shit... like i said as true ATV as possible!
Build from Latest source, all changes done in source itself...
Btw from now on im going to be very "economical" about my changelogs...
THIS BUILD IS FOR SN: 922X
Differences of USER and USERDEBUG builds:
User Build: This build is done to be as close to a company rls as possible, it does not have root or twrp and is compiled with rls keys and SELINUX enforced, what this means for you?
Well it means lot more apps show in Playstore that dint show before, (EX: my isp androidtv live tv app, only shows in Playstore non rooted and SELINUX enforced devices, also the streams in the app does not even play in rooted devices.). Like this there's lots of other ISP/NON ISP apps Out there....
UserDebug Build: This build does have root, twrp, selinux is permissive and some other stuff you will see in changelog down there.., but of course you will lose the above...
CHOOSE YOUR VENNON........
Changelog v1.0:
- Build from latest AML Pie SDK
- Real ATV Build Path used.
- Reboot to TWRP or Switch OS ( Only on UserDebug build )
- Fixed the annoying random waking up from sleep or shutdown.
- Added bluetooth to side settings.
- Added small delay on google assistant, so on default remote you need to keep the button pressed to work, single press does not work.
- (Cont. from above) i did it like this since this remote need you to keep the MIC button pressed for listening you.
- Some cleaning of unneeded stuff for regular ATV functions.
- And lots of other stuff...
- There is a bug in setupwizard where you choose to install some apps or not, well it installs all of them even if you do not choose anyone..
- Googlecast will not work ok, nothing i can do to fix it since it need certification.
- Netflix for AndroidTV will not work at all, so use regular netflix already present in the rom.
Want to buy me a beer?
Download:
- DOWNLOAD HERE SC v1.0 ATV USER BUILD IMG
- MD5: 0F73ED2BB44D08F846F79B697335CB64
- DOWNLOAD HERE SC v1.0 ATV USERDEBUG BUILD IMG
- MD5: 9916DDC181505D58CE2B8350A7883C61
Install instructions:
- Use usb burning tool v2.2.0 to burn the IMG.
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
USE AT YOUR OWN RISK!
Enjoy it!
