Magicsee N6 Plus Android 9.0 4G + 128G Smart TV Box - Black 4GB DDR4 + 128GB ROM
Information as Found:
A Device Leads You
Are you looking for a device integrating various entertainment activities to enrich your visual and auditory experience at home? Here comes the Magicsee N6 Plus TV box, which provides massive videos and games without buffering or breaking down, making every moment enjoyable. With the high-performance software and hardware, Magicsee N6 Plus TV box is always to lead you into a magical world once you turn it on.
Main Features:
Rapid and Responsive Running
Equipped with the high-performance Amlogic S922X Hexa-core, Magicsee N6 Plus TV box runs fast and smoothly with excellent heat-dissipation, never worry about buffering and overheat while you are watching movies or playing games.
Great Compatibility
Adapting the Android 9.0 operation system, Magicsee N6 Plus is compatible with more software, games, and applications, improving users' experience.
Unparalleled Video Display
4GB DDR4 allows you to display high-definition video smoothly, and eMMC 128GB storage memory supports you to download massive resources from the internet, such as movies, software, and applications.
Stable and Fast Data Transmission
2.4G + 5G dual-WiFi and 1000Mbps LAN run internet, streaming and audio perfectly without jerking, which allows you to play 4K @ 60fps, 3D and H.256 videos smoothly.
Convenient to Control
Speak to the 2.4G voice remote control, and it will operate the TV box based on your demand. And support air mouse function.
Screen Rotation
We added portrait and reversed modes for rotation screen, It will be useful if you dome non-standard application or digital.
Hardware Monitor
CPU, temperature, network, load ram realtime performance, each one is under control: CPU load, internet speed, RAM usage, temperature.
Dynamic HDR Support
Dynamic HDR support ensures every moment of a video is displayed at its ideal values for depth, detail, brightness, contrast, and wider color gamuts-on a scene-by-scene or even a frame-by-frame basis.
Parameters:
CPU: Amlogic S922X Quad core ARM Cortex-A73+Dual core ARM Cortex-A53
GPU: Arm Mali TM-G52 MP6 ( 6EE )
System OS: Android 9.0
RAM Type: DDR4
RAM: 4GB
ROM: 128GB
Wi-Fi: 2.4GHz / 5GHz, IEEE 802.11a / b / g / n / ac, 2 x 2 MIMO
BT: 4.1
Ethernet: 1000Mbps
Lets Have a look:
Box:
What is in the Box
Ports
Remove the base
Out with the PCB
https://www.gearbest.com/tv-box/pp_0...&lkid=78642181
For more information or discussion:
https://forum.freaktab.com/forum/tv-...lan#post794863
