X96 Max - ethernet disconnects when trying to connect to server in Surfshark app (IKEv2)
    Hello guys,
    Box1: X96 Max 4/64 x905x2
    Fw: V311R_P_20191223-1456 (upgraded from OTA, seems latest)
    More details:
    Issue appears only with protocol IKEv2 and OpenVPN/TCP in Surfshark app.
    Do you have that issue too?
    What ROM should I test to fix that?
    Thank in advance for support.
    Did you mess with the "Developer Options" menu?
    I had an Ethernet connection bug in one of my devices running Android 9, can't remember which, but the problem was solved by changing a Developer setting...
    Also can't remember which setting to be exact, but try these Networking settings 1) the setting "Mobile data always active" - turn ON if disabled, and 2) "Default USB configuration" - set to File Transfer. Both settings are safe to change to, nothing adverse will happen, but hopefully it helps.
    Test it out!
    Cheers
      @RiCkLaR_atvX
      Developer options not activated. Anyway I'll try your workarounds, thanks.
      Btw. I have the same issue on other device X96 Max+ 2/16GB s905x3 but it appears only when I open Surfshark app.
      Maybe Android 9 (mobile) is not compatible with that app.
      Edit:
      Seems like the app is creating issue and disconnects ethernet.
        Guys issue is fixed on X96 Max 4/64 x905x2 but it's still there on X96 Max Plus 2/16 s905x3..
        I think that Surfshark app is not compatible with all Android 9 firmwares.
        EDIT:
        Issue appeard again on both boxes.
        It connects to server with protocol OpenVPN/UDP and Shadowsocks but can't with IKEv2 and OpenVPN/TCP.
