One for the Inner Allwiner fans, small compact
Sizes to be had 2/8, 2/16 and 4/32GB
Android 9.0 OS
It is based on the latest Android 9.0 OS, with high speed and smooth performance, which is designed to turn your regular TV into a smart one.
AllWinner H6 Quad-core ARM Cortex A53 Processor
T98 Mini adopts Allwinner new H6 quad-core high-end master chip, which is Cortex A53 architecture.
6K UHD Resolution
The TV BOX Fully supporting premium 6K UHD contents with a powerful 64bit CPU and T 720 MP2 GPIJ combination in place to handle 6K graphics and offers strikingly realistic pictures.
Specification as found
General | Model: T98 Mini Type: TV Box |
Hardware | System: Android 9.0 CPU: Allwinner H6 Core: Cortex A53,Quad-Core GPU: Mali-T720 RAM: 2G DDR3 ROM:8G eMMC Max. Extended Capacity: 32G |
Communication | 5G WiFi: No WIFI: 802.11 b/g/n Bluetooth: 4.0 |
Media | Decoder Format: H.263,H.264,H.265,HD MPEG4 Video format: AVI,DAT,ISO,MKV,MP4,MPEG,RM,WMV Audio format: AAC,FLAC,MP3,OGG,RM,WMA Photo Format: BMP,GIF,JPEG,JPG,PNG,TIFF Support 5.1 Surround Sound Output: Yes |
Interface | Micro USB Port, HDMI, TF card slot, USB2.0, OTG |
Other Features | Power Supply: Charge Adapter Antenna: Built-in Camera: Without Language: Multi-language HDMI Version: 2.0 Other Functions: DLNA, ISO Files, Miracast |
Power | Power Consumption.: 6W Power Type: External Power Adapter Mode Remote Controller Battery: 2 x AAA Battery ( not included ) |
Dimensions&Weight | Product weight: 0.048 kg Package weight: 0.200 kg Product size (L x W x H): 9.00 x 4.00 x 1.50 cm Package size (L x W x H): 21.00 x 12.00 x 8.00 cm |
Package Contents | 1 x TV Box 1 x HDMI Cable 1 x Remote Control 1 x User Manual |
