PD: It included catches of the publication and of the buyers.
Have you tried the X96 Max X3?
I bought the X96 Max X3 apparently there are 2 models X96_Plus and X96_Plus2 and both have the S905X3. In Ali they publish it as Plus (+) but without the symbol. I really don't know if it's the same model, a new model or a clone.
PD: It included catches of the publication and of the buyers.You may only view thumbnails in this gallery. This gallery has 8 photos.8 PhotosTags: None
Originally posted by majkool View PostX96 are:- X96 Max
- X96 Max Plus
X96Max_Plus2 could be name ported from 2GB firmware or version with DD4 RAM.
X3 is just a short name of SoC S905X3.
Can you share link to Ali?
Para ver ?555.68 MXN$ 44%de DESCUENTO | Dispositivo de TV inteligente X96 Max X3 Android 9,0 caja de TV X96Max 4K Media Player Amlogic S905X3 8K caja de Android 2,4G y 5G Wifi 4GB 64GB 1000M LAN? en AliExpress con el código #_dVmWYs9#, copia toda la frase y abre la app.
@Bileygr666
You shouldn't use fw from Max Plus on Max because it could have different WiFi chip etc. But I think it should not brick the box so you can go back to Max fw.
Sorry for posting this on all the x 96 max forums but I'm desperate.
I have several of the x96 max plus2, newly purchased ( some came today ) and the wifi is not working properly. I did the ota updates and it's up to 20200620-1131. The wifi connects, speedtest reports the right speed. Everything seems ok until I try to run cinema or filelink,stremio, all vod apps. They load very slowly on each step. Filelink won't open at all. I'm highly invested and really need help.
There are currently 2674 users online. 1 members and 2673 guests.
