3d Launcher icons - G-Box MX2 & clones
    3d Launcher icons Mark as best answer
    Hey Guys
    I am stuck! I want to know how to add / delete / change the icons on the home page of the 3D launcher. See my attached image.
    We managed to uninstall XBMC - had reloaded it but cannot work out how to get it back onto the front page of the 3D launcher
    Live as if you were to die tomorrow. Learn as if you were to live forever
    Can you send me the APK ? Then i can watch Inside and see how to do this.
    Neomode
      Re: 3d Launcher icons - G-Box MX2 & clones
      Neomode
      Ha ha - its sods law isn't it? Just gone out for a curry.
      Will send you it when I get back, ok? :-)
      Sent from my GT-I9300 using Tapatalk 2
        Yes you are right Murphy is going his way ;-)
        Send when you can.
        Neomode
          On the stock launcher you edit the APK and edit the file default_workspace.xml
          However it maybe very different for the 3Dlauncher.
            Cheers Bob - will give that a whirl
