Understand this box with logo, TX9, an imitation of TX3, that is, the staff said that a plate is a mini tanx TX3, I didn't go to the tanix website and downloaded an original to change the logo from the beginning, please later the update or bluetooth does not work or mini time display nothing appears and the wifi does not find any network, does anyone know what i can do, i wanted to use this box with alice ux as it is for my mother and it is easier to move.
help with TX3 mini Fake
Originally posted by thiagopires View PostUnderstand this box with logo, TX9, an imitation of TX3, that is, the staff said that a plate is a mini tanx TX3, I didn't go to the tanix website and downloaded an original to change the logo from the beginning, please later the update or bluetooth does not work or mini time display nothing appears and the wifi does not find any network, does anyone know what i can do, i wanted to use this box with alice ux as it is for my mother and it is easier to move.
you installed a wrong FW , with support for other Chips , you must look for
a CustomRom from here , look at your Specs , CPU / GPU / Wifichip , and
look for the right FW , read the TX3mini Threads from here , there you can
find FW too , if it is really a TX3mini , what stands on the Sticker and on
PCB printed ,
good luck / gefattern
Guest
Originally posted by thiagopires View Post...box with logo, TX9, an imitation of TX3, that is, the staff said that a plate is a mini tanx TX3...
Originally posted by thiagopires View Post...bluetooth does not work or mini time display nothing appears and the wifi does not find any network...
thank you very much for the answers, when you didn't find anything to do as before, will it be that if i take another device like that, and make a backup and install the backup in this problem it will come back? another question, i saw or the happy chick works with ps3 controls via usb in this version of PoisonATV 4.9 s905w, how can you copy some folders that may work on alice ux controls?
There are currently 3624 users online. 0 members and 3624 guests.
