mxq pro+ 4k 2gb 16gb s905w with wifi rtl8703 not work wifi
Hello. I have a tv box mxq pro+ 4k 2 / 16gb s905w with wifi rtl8703 - S905XQ4_V3.0 mainboard. After the failure, I wanted to resuscitate my TVbox, nowhere could I find a rom that would match my pro+ version. So I uploaded the img firmware from another 'mxq pro 4k' with the s905w processor. https://androidpctv.com/firmware-mxq...oc-12-18-2017/ But after uploading, only the wifi module does not work. Could it be somehow fixed? Is it possible to transfer drivers from another to my version android 7.1.2. Please help. THX!Last edited by biuro.service.tube; 05 April 2020, 20:53.Tags: None
Welcome back. After testing other firmware for s905w, I finally found everything where it works, this is the ROM for "s905w T96 mars 20181105" [ https://drive.google.com/file/d/1Evc..._dqbiwfiK/view ] . Android detects drivers for WiFi rtl8703 and Bluetooth, the remote control works. But there is one problem, WIFI works, I can add a network and it has to connect to the router and the internet works, but when it turns off wifi can not be turned on again. Then get again the MAC address is 02:00:00 ..., it only helps to restore factory settings. How can I fix it so that I can switch WIFI on and off?Last edited by biuro.service.tube; 05 April 2020, 20:54.
There are currently 1444 users online. 2 members and 1442 guests.
