Fix IDB failure for RK devices
    Steps for repairing IDB failure are:
    1-use Andriodtool v 2.51 or higher
    2-you have to have a working loader (you can unpack any working rom using andriodtool by going to _Advanced Function_ and from here download a working firmware and unpack it by pressing unpack. Note, you can find the (loader) in (output folder created by Andriodtool).
    3-using Andriodtool, go to download tab and from there you can see (loader)(parameter) etc. jst focus on loader and upload that loader and put mark so that it can be flashed to your device.
    4-let Andriodtool reconized your device as Maskrom device.
    5-Finally, before hitting (Run), make sure you use tweezers or anything to to short circuit (GND and CLK inside the board) and hit run.
    6-The device will flash the loader into the board and you can now download a working rom for your device easily and get rid of IDB failure.
    Note, If the above steps do not work with you, you can try :
    1- press the recovery button on the device and (hold it)
    2- Open Andriodtool 2.51 and upload a working firmware and hit (erase flash while holding the recovery button).
    3-If you do not succeed with andriodtool, you can use factory tool ( 1.6, 1.63, or any version)
    4- I hope this second method will work.
    Note, I need stock rom to unbrick my X88 Max plus, please if anyone can help me, I appreciated so much, please
    Hi ,
    thanks for this , i make him sticky , better to find then ,
    greetings / gefattern
      Hi ,
      Hello Gefattern!!
      Thanks for your post but everytime i try to load the loader on androidtool the app closes. Can you help me please?
        Originally posted by bibosbibos View Post
        Hello Gefattern!!
        Hi ,
        Drivers installed ???
        did you check the Loader in Tool ???
        which ATool did you use ???
        what Loader did you use ???
        Maybe your Box has another Problem , which Box ???
          Hi Haizenberg, do you have the link for Android Tool v.2.51? Can’t find it here. Thank you!
            I dont have firmware in img type ,
            i dumped firmware from another box of same kind using parameter in android tool
            how to get loader file
              Hi ,
              CAN YOU HELP ME TO SPOT GND AND CLK PINS
                Hi ,
                think the four golden holes , left of CPU Chip , but they not marked as ... ,
                the Loader can be extracted from full .img file with Androidtool 2.38 or above , third tab , load .img to "unpack" row & unpack , the single files will be saved in AT Folder under
                Output , i think ,
                good luck / gefattern
                  Hi ,
                  Output , i think ,
                  i dont have .img firmware , i have in .zip type only
                  can i get it from another working box??
                  thank you
                    thank you
                    Hi ,
                    .zip is a compressed file , you can uncompress it with 7zip tool on PC ,
                    or any Zipper App from Store on Handy , no need to do something else ,
                      Hi ,
                      but it dosent have loader file,
                      let me share u link of that file
                      Last edited by charan; 29 June 2020, 13:41. Reason: https://drive.google.com/file/d/1W3aiq8O94WxVr7R176SkPMJzrzeVDvve/view?usp=sharing
                        https://drive.google.com/file/d/1W3a...ew?usp=sharing
                        Hi ,
                        i already explained how too extract loader from .img file , first unzip than unpack with Tool , and please stay with your Problem in one Thread , lets go on in the other Thread of you , no need to do twice ,
                          NO YOUTUBE TEM VÍDEO PRA RESOLVER ERRO IDB ??OU FOTOS DE ETAPAS NO GOOGLE ??
                            Hi ,
                            please use English ,
                            gefattern
                              SORRY
                              YOUTUBE HAS VIDEO TO SOLVE BID ERROR ?? OR PHOTOS OF STEPS ON GOOGLE ??
