Specification
General | Model: X96M Type: TV Box |
Hardware | System: Android 9.0 CPU: Allwinner H603 Core: Quad Core GPU: Mali-T720 RAM: 4G DDR3 ROM:64G eMMC |
Communication | WIFI: 802.11 b/g/n |
Media | Decoder Format: H.264, H.265, VP9/VP6/VP8 Photo Format: HD JPEG, BMP, GIF, PNG, TIF Support 5.1 Surround Sound Output: Yes |
Interface | AV,DC 5V,Ethernet,HDTV Out,Optical,TF card,USB2.0,USB3.0 ,Type-c |
Other Features | Power Supply: Charge Adapter Language: Multi-language HDMI Version: 2.0 HDMI Function: HDCP Other Functions: DLNA, Others RJ45 Port Speed: Support 10/100Mbps |
Power | Power Consumption: 10W Power Type: External Power Adapter Mode Power Input Vol: 5V Power Adapter Input: 100-240V / 50-60Hz Power Adapter Output: 5V 2A Remote Controller Battery: 2 x AAA Battery ( not included ) |
Dimensions&Weight | Product weight: 0.1780 kg Package weight: 0.400 kg Product size (L x W x H): 13.50 x 9.00 x 2.30 cm / 5.31 x 3.54 x 0.91 inches Package size (L x W x H): 18.80 x 14.70 x 5.50 cm / 7.87 x 4.92 x 1.77 inches |
Package Contents | 1 x TV Box 1 x HDMI Cable 1 x Remote Control 1 x English User Manual 1 x Power Adapter |
