MK908 doesn't start after flash or after firmware restore
I'd flash it with this ROM (http://www.freaktab.com/showthread.p...inless-ROM-1-6) without failures. It doesn't start, my TV gets no signal.
I'd restore it with this firmware (update_mk908_106j2107_04.img and also Tronsmart mk908 new stock firmware 0802update.img) without failures. It doesn't start, my TV gets no signal.
some minor thoughts
A, monitor issue or hdmi cable ( *try differend one)
B, powersupply issue ( see * )
C.you used a wrong way to flash? ( did you use a manual? what tool did you use.. give more inside/info)
D. you have a other model.. there are about 6 version of the mk908
Looking at feedback.. (finless rom) his fw works on v1 and 3 ( that leaves with? )
anyway try option 1&2&3 first.. if it fails..
try opening case.. and posting pic's of pcb
