looking for t95 max + rom
Hi Drsam007,
I just downloaded your version of the firmware from the link above.
Did you install it on one of these (I'm worried about getting confused by all the similar names)
Also, are you able to tell me what differences there are between the standard interface and the superceleron build you uploaded?
I really don't like the box I bought, primarily as it doesn't output the picture after rebooting unless I unplug the hdmi cable and the top status/notification bar is missing on this box so I can't see at a glance if my VPN is connected. Additionally, I also noticed that Google Chrome tells me it's out of date (v70) but play store won't let me update it.
Cheers
Dan
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
There are currently 4075 users online. 0 members and 4075 guests.
