Audio does not output from HDMI (video is fine) - however it will randomly start at some point after it has been booted for a while (nothing specific seems to trigger it starting to work, it just does - this could be 20 mins to an hour)
This is ONLY with my LG TV - it works fine with another TV;
this issue is also the same for another user with same box, same ROM and also an LG TV - so suspect it does not like something about the EDID from the LG - however that other user also has an X96 box running 7.1.2 which plays perfectly on his LG - the audio_policies look very very similar; I suspect the Kernels are different and why they behave differently; that other user also experiences the same random 'suddenly starts working' condition.
I have tried to force default HDMI output via the audio_policy.conf and that made no difference
I have attached the dmesg logs filtered for 'hdmi' and 'audio' and also the audio_policy file - perhaps someone could take a look and see if anything sticks out as to why it does not output to the HDMI
Thanks for looking and for any suggestions you may have
dmesg_hdmi.txt
dmesg_audio.txt
audio_policy_conf.txt
