x92 S912 3GB DDR3 32 GB ROM Android TV Box bricked..Turns on, but no hdmi out, only green light on Ethernet port-Help needed
    I flashed wrong Tanix T9 Pro rom (TX9pro-20180205.img) which I downloaded from Tanix site. Initially flashing was failing at 2% receiving the error "[0x10105002]Romcode/Initialize DDR/Read initialize status/USB Control setup error" .Then I read somewhere that uncheck the "Erase bootloader" option in the amlogic flashing tool helps. It unchecked Erase Bootloader option and flashed the rom successfully. After that, Box rebooted with no signal on Monitor, but Greenlight on the ethernet port is there and Optical Out red light comes when power cable and USB cable to PC connected.
    I again tried to reflash the original rom, but amlogic flashing tool is not detecting the Android Box,I tried with memory card flashing also. Not working.
    Click image for larger version  Name:	20200401_133257.jpg Views:	1 Size:	98.9 KB ID:	800998
    Someone please help ...
    Hi All,
    Hi ,
    first you need the Stockrom to restore , then you must bring your Box in the so called
    MaskRomMode , this can be done by shorting two Pins on your NandChip , or similar
    two points on PCB , you can find all Infos about MRM here in the Forum ,
    good luck / gefattern
      This might help a bit...
      I had a question I hope someone could help with. I have an H96 Pro Plus box the CPU is a S912 3GB RAM 32GB of storage. It is bricked and one other post
        Try this maybe
        No HDMI outs
        Use the av port out to TV and old camera patch cord should work/composite yel/red/white see if you have video....
        This also seems like the classic power supply prblem ....
        5 volts at 3 amp required...
        These issues always seem to happen after a soft brick....
