Anyone get Disney+ official app working on Mecool Kiii Pro??
Hey,
has anyone managed to get the Disney+ official app (Ver 1.1.5) working on Mecool Kiii Pro??
I have tried the stock 7.1.2 rom, Superceleron's Android TV and Normal Rom. I can get the Disney+ app to load with profiles etc but it just wont play anything.
I used the same app on my Minix U1 and H96 Plus with no problem, they both play everything!
Just seems to be a Mecool Kiii Pro problem. I have also tried various versions of the Disney+ app but no joy!
This is likely of no help...I have not watched Disney...since... Wonderful World of Disney ....ages ago.
You probably need a certified device (widevine L1 - strict)
If you get it to run at all on other devices...AdGuard(?),VPN(?), host file(?) root(?),Xposed(?) or combinations...feel free to share!
Hello, thank you. Already tested with and without vpn, the application launches, we see the various films, series, but as soon as we launch one of them, there is a circle that rotates continuously.
Can't install the apk of the play store.
I have a Mecool M8S Pro+ and I have the same problem. I bought it almost a year ago, I only used it a couple of months before the Netflix chaos emerged (I bought it mostly for Netflix). Now I wanted it to give a second chance and run Disney+ and testing yesterday I run in the same problem, I live in latin america so I have to use a VPN, I can login in Disney+ and I can see the splash screen and the various series and movies, I can navigate through the menu and enter each item page, but when I try to play it the screen change to the loading screen as if its buffering (the rotating blue circle) and stays there forever.
Man this is probably the worst purchase that I made. This box was a way to replace my Chormecast but it didnt work. Like I said I'm from latin america, so if I want to screen Disney+ to the Chromecast I have not only to run the VPN in the phone, but also on Chromecast, I think I have a router with DD-WRT so I can put the VPN info on it.....
Try disabling L1. To do this find liboemcrypto.so on your box and rename it to libeomcrypto.so.bak. On the Mecool KIII pro, go to the root directory, then system > vendor > lib
Alternatively, if your box is rooted with magisk, install the liboemcrypto disabler module.
This fix works for the Netflix app (540 res only) so it should also work for Disney+ if it's an L1 DRM problem
Another option is the Disney+ addon for Kodi, though you may still need to disable L1. You'll find it in the Slyguy repository: http://k.slyguy.xyz/
Kodi runs best on coreELEC, which will run on almost any Mecool box, and will also give you Netflix in 720 HD without needing to disable L1. Instructions to install it on a microSD (or USB stick) in this post
