Q box amlogic s905x marshmallow 6.01 stock firmware
Hello, I have a 2016/17 Q box amlogic s905x with android marshmallow 6.01 version qb0005. I believe the firmware became corrupt so I looked everywhere for the stock firmware but couldn't find it. The only firmware I found that worked was marshmallow 6.01 version qb0003 which is really old and play store would not update either. Does anyone have the stock firmware or maybe an updated version like android 7.1 for this box please?Tags: None
Originally posted by indiekid!!! View PostHello, I have a 2016/17 Q box amlogic s905x with android marshmallow 6.01 version qb0005. I believe the firmware became corrupt so I looked everywhere for the stock firmware but couldn't find it. The only firmware I found that worked was marshmallow 6.01 version qb0003 which is really old and play store would not update either. Does anyone have the stock firmware or maybe an updated version like android 7.1 for this box please?
hi all , never posted before but have read this forum for about 4 years, its helped me out many a time and a big thanks to everyone who contributes .
Perhaps you have ddr4 memory.Because of this ,there are few ddr4 firmwares.
Originally posted by indiekid!!! View PostI couldn't any firmware for it. Here's the link to the box I have. I just need either the stock firmware which was marshmallow or an updated firmware that will work with it?
https://justop.com/catalog/q-box-4k-...wifi-17-3.html
Guided UTV Ecological Observation Scenic Tours at Chiriaco Summit in the newly designated Chuckwalla National Monument. Fun offroading with care and intention for protection and nature connection. Palm Springs, Coachella Valley, Indio, La Quinta, Joshua Tree National Park.
Firmware S905X V2FF 1GB/2GB RAM DDR3/DDR4 (18.10.2018)
Guest
Originally posted by indiekid!!! View Post...The link is some buggy tour place?
Originally posted by indiekid!!! View PostOne small problem with the new firmware is that I can't turn the led light off on my box which flashes blue green light if when I've shutdown the box. I need an app like this one I have seen on another box. Anyone know how I can get one?
you mean the light around the Box ??? , if , you can open up and unplug it , if i remember good ,
good luck / gefatternLast edited by gefattern; 06 April 2020, 18:25.
There are currently 4090 users online. 0 members and 4090 guests.
