Android 9.0 operation system
Amlogic S905X2 Quad core ARM Cortex-A53 CPU
ARM Mali-G31 MP2 GPU
4GB LPDDR4 + 64GB EMMC
2.4GHz + 5GHz dual band WiFi
1000Mbps Ethernet
Support 4K ultra HD imagedisplay
Support H.265 decoding
Last week the hdmi port stopped working, i tried several cables and ran a factory reset but the screen still flickers a lot.
I bought it from Aliexpresss but im doubting i will get a repair from them.
I am considering buying a hdmi port replacement and soldering it to box, but i am not sure which type of hdmi port i would need.
Are the Android boxed a standard hdmi port, would anyone know which one i would need.
thanks
