Hopefully one of you lovely people can help me identify and point me to the firmware file I need to fix this thing up.
I forced flashed a version of S905 on the unit after trying and failing to get for probably 10 hours to get 10+ different versions of S905 on there via multiple methods. The unit had the following specs listed when I brought the unit 18 odd months ago.
Key Features and Product Specification:
Product: OTT TV Box Model X96
CPU: Amlogic S905W Quad Core ARM Cortex A53 @2GHz
GPU: Penta-core Mali-450MP GPU @ 750MHz
OS: Android 7.1.2 Nougat
ROM: 16 GB EMMC Flash
RAM: 2 GB DDR3
USB: USB2 x 2
Video Output: HDMI
Power Supply: Standard AU/NZ 5V @ 2A
Video Resolution: 4K x 2K Ultra HD (UHD) and 3D-HD
Network: built-in Wi-Fi 2.4GHz and 10/100M Ethernet Port
I was so happy when I finally managed to get something on there but that happiness was short lived as when I rebooted I only have the red light.
I can still access the unit via the USB burning tool but not via recovery or SD card boot. I tried for a couple of hours to get firmware back on there but had no luck at all so decided to open the unit up so I could compare the board to pics in varies forum posts. You can imagine my happiness when I discovered it is only an Amlogic S812, 2/8GB, GPU only running 450Mhz blah blah but at least I now knew why all the flashing attempts were failing so badly.
Ive now spent another 10 odd hours reading forum posts and trying different firmwares, versions of USB burning tool, options in USB burning tool etc but once again no luck. Basically all the firmware files fail between 90-96% complete when writing from USB Burning tool. Multiple different errors mainly dependent on version of the tool it seems but always around that percentage.
I hate it that this crappy thing has beaten me and forced me to ask others for help but someone please help me!
