Why do they crash?
    Why do they crash?
    I got in another MX10 Pro 6K, i really like these larger MXQ style cases with the 4 vertical USB ports i know its old tech no bluetooth but they have one of the best cases to mod a fan inside.
    So its bone stock i havnt even looked inside as the heatsink on it yet
    I installed Asphalt 8 and i just did the mini game at the begining when it downloads the game you can run around and get these coins.
    The unit crashes and goes black not even an LED on the front its like no power at all.
    Get out my Deox-it spray and i spray the 2 1/8" holes (AV and SPDIF) plug it back in and its been running fine for the last hour.
    My question is, what are these 2 ports? I know what they are for AV out for older tvs that dont have HDMI and the SPDIF is a digital sound out but why would either of these 2 ports (not sure which one has the issue) why would they cause the unit to crash if there is a bad connection in em?
    Im trying to understand what they would be doing, a common ground?
    I did notice before it crashed the audio was skipping here and there cutting in and out, now after i sprayed it it hasnt dont it since.
