X88 Pro with RK3328 chipset, Android 9 // Root? Firmware?
    Originally posted by Silver View Post
    Get a better box to play with, the CPU is low powered it cannot keep up with todays needs.
    I know, it is not a "power-machine", but I use only to watch the TV (via Android app), sometimes YouTube
    Finally, I have done, root + change the launcher, my steps, if anybody is interested in:It works and is suitable for me.
      Many devices cannot be rooted with magisk, needs to have build with magisk flag in boot.img
      Great you got yours rooted, what is that LSpeed app? i never heard of it
        Yes, for this device I had to patch "off-line" the boot.img, as in the forum has been described: https://4pda.ru/forum/index.php?show...ost&p=95053487
        Translated by Google:
        9. Boot from the device, install MagiskManager-v7.5.1.apk
        10. Run magisk, start the Internet, go to the advanced settings and put one daw "Installation mode in recovery"
        11. Opposite to magisk 20.3, click “Installation”, select “Installation” and then click “Patch the image manually and select our boot.img
        12. Copy the magisk_pached.img file from the download folder to the sd card
        LSpeed is a tweaking app, I like it, because I have set-up a performance-oriented profile:
        "L Speed is a modification that combines tweaks inside an intuitive application, the main goal of the tweaks is to improve performance, reduce stutters and lags, expands battery life and improve your gaming experience on Android.
        The mod will and should work on any device that meets its minimum requirement.
        You only need a rooted Android device and Android 4.1+ for L Speed app to function properly."
          Bro, did problem solved?
            Absolutely. If you want to purchase now, I have good news: the manufacturer published a new firmware: https://sunnzo.com/download/ (and then: https://drive.google.com/file/d/1QfZ...HHyQW5Oty/view ) which is rooted by default, it means, you should not do any magic furthermore.
              Thanks. is your box RK3318? My box board says RK3318 but recovery mode says RK3328. And my x88 pro bricked and I must find nand shot pins
                Thanks. is your box RK3318? My box board says RK3318 but recovery mode says RK3328. And my x88 pro bricked and ? must find nand shot pins ?
                RK3318, I opened my box and somebody also did it: https://wasp.kz/articles.php?article_id=1222 , RK3328 is a lie.
                No, I could re-flash so many as I wanted with RK Batch Tool 1.8 https://www.allmobitools.com/downloa...ip-batch-tool/ , just I pressed the reset button. (as usual)
                  Ссылки не рабочие. Есть рабочие ссылки?
