HDMI output
HDMI output
Good day everyone, i have some boxes here,thing wrong with them is there all turning with the blue light and every but am not getting any signal from the HDMI port... I i used the rca connection and i can see them on the tv.. So i tried different HDMI cables my other cable that i use alot 2 of them are showing up with that cable but 2 are not.. The cable that i use on my pc works with my other boxes but not with these... I am debating if its the port on the boxes or i just need some other hdmi cable.. I have a brand new box still in the box so i tried the cable that comes with that but still no signal.. What do you guys think is the problemTags: None
Originally posted by shadydawg View PostGood day everyone, i have some boxes here,thing wrong with them is there all turning with the blue light and every but am not getting any signal from the HDMI port... I i used the rca connection and i can see them on the tv.. So i tried different HDMI cables my other cable that i use alot 2 of them are showing up with that cable but 2 are not.. The cable that i use on my pc works with my other boxes but not with these... I am debating if its the port on the boxes or i just need some other hdmi cable.. I have a brand new box still in the box so i tried the cable that comes with that but still no signal.. What do you guys think is the problem
If it's low cost devices, they are most likely broken or have a faulty HDMI port.
This is what ive been wondering about my boxes, those little 3.5mm ports i think have issues.
#1, they always put the reset switch in the "AV" jack so what are we doing? poking things into this port, whats this doing?
Will these units run both outputs at the same time? if not then what is it defaulting to the AV port? or the HDMI?
If its not displaying both at the same time what determines which output the box uses? Is it a mechanical switch that decides or is it what?
There are currently 3595 users online. 0 members and 3595 guests.
