Vontar X3 bricked by it self-only red light
    Hello to everybody,
    I dont know why but is truth...Vontar X3 bricked by it self. Can't turn on. Only the red light remained. Tried flash with USB Burning Tools - stopped at 7%. Same thing with Burn Card Maker-SD. I used VONTAR_X3_1000M_9.0_S905X3_2020.01.13, HK1_X3_S905X3_2019-11-23, u218.VONTAR_X3_1000M_9.0.2019.12.28.11.18 and u218.VONTAR_X3_1000M_9.0.2020.01.13.12.20 img without success. Is there anything I can do with UART and how (instruction)? The device is recognized by USB.
    Thanks for the help.
    Can you try something for me?
    Push a male plug into both 3.5mm jacks and pull them out really quick then try and boot it up
    Maybe put the plug into this jack and twist it wround before you pull it back out
    I have a MX10 that just quit on me also, it was working a week ago before i put it back into the box now it wont boot up
    Click image for larger version  Name:	bad jack.jpg Views:	0 Size:	179.7 KB ID:	803398
      Nothing happens ... same thing. I tried everything. With and without power...with toothpick, shortening two pins on the back side...nothing.
          Originally posted by grayman View Post
          "shortening two pins on the back side...nothing"...
          Connected with UART:
          Rx to Tx
          Tx to Rx
          Gnd to Gnd
          I only get nonsense in the terminal ... what's going on ???
          Attached images.
            Rx to Tx
            Tx to Rx
            Gnd to Gnd
            Attached images.
            1. Srart USB Burnig Tool. Load your image file and press "START".
            2. Connect one end (USB-A) of your cable to your box.
            3. While shorting the 2 pins connect the other end of your cable (also USB-A) to your PC/Laptop and keep connecting for 2-3 seconds (until you hear a beep). Stop shorting the pins.
            Also you can try without shorting the pins and when it stops at 7% just UNPLUG the USB cable and REPLUG it without doing anything else. It is possible that it will continue burning beyond the 7%.
              I've done it 100 times and always stopped at 7%...
                Did you try unplugging and replugging?
                OR in another try
                Did you check "Full Erase" instead of "Normal Erase"?
                  OR in another try
                  I did, of course ... . I was able to start flash via UART, but it interrupts the process ... I'm looking for another img ...Is there any recovery img for this Vontar?
                    https://yadi.sk/d/kUjKMLyIrUBshQ I don't know if this is different than the ones you already tried. It was uploade on 14/2/2020.
                      I get this with UART...
                      SM1:BL:511f6b:81ca2f;FEAT:A0F83180:20282000;POC:F; RCY:0;EMMC:800;NAND:81;SD?:0;SD:0;READ:0;0.0;CHK:0 ;
                      bl2_stage_init 0x01
                      bl2_stage_init 0x81
                      hw id: 0x0001 - pwm id 0x00
                      bl2_stage_init 0xc0
                      bl2_stage_init 0x02
                      no sdio debug board detected
                      L0:00000000
                      L1:00000703
                      L2:00008067
                      L3:15000020
                      S1:00000000
                      B2:20282000
                      B1:a0f83180
                      TE: 1923895
                      BL2 Built : 20:29:41, Jun 18 2019. g12a ga659aac - luan.yuan@droid15-sz
                      Board ID = 1
                      Set cpu clk to 24M
                      Set clk81 to 24M
                      Use GP1_pll as DSU clk.
                      DSU clk: 1200 Mhz
                      CPU clk: 1200 MHz
                      Set clk81 to 166.6M
                      DDR driver_vesion: LPDDR4_PHY_V_0_1_15 build time: Jun 18 2019 20:29:37
                      board id: 1
                      Load FIP HDR from SD, src: 0x00010200, des: 0xfffd0000, size: 0x00004000, part: 0
                      fw parse done
                      Load ddrfw from SD, src: 0x00060200, des: 0xfffd0000, size: 0x0000c000, part: 0
                      Load ddrfw from SD, src: 0x00038200, des: 0xfffd0000, size: 0x00004000, part: 0
                      PIEI prepare done
                      fastboot data load
                      fastboot data verify
                      verify result: 255
                      Cfg max: 5, cur: 1. Board id: 255. Force loop cfg
                      DDR3 probe
                      ddr clk to 672MHz
                      Load ddrfw from SD, src: 0x0002c200, des: 0xfffd0000, size: 0x0000c000, part: 0
                      dmc_version 0001
                      Check phy result
                      INFO : End of initialization
                      INFO : ERROR : Training has failed!
                      1D training failed
                      Cfg max: 5, cur: 2. Board id: 255. Force loop cfg
                      DDR3 probe
                      ddr clk to 672MHz
                      dmc_version 0001
                      Check phy result
                      INFO : End of read enable training
                      INFO : End of fine write leveling
                      INFO : End of read dq deskew training
                      INFO : End of MPR read delay center optimization
                      INFO : End of Write leveling coarse delay
                      INFO : End of write delay center optimization
                      INFO : End of read delay center optimization
                      INFO : End of max read latency training
                      INFO : Training has run successfully!
                      1D training succeed
                      aml_ddr_fw_vesion: LPDDR4_PHY_V_0_1_15 build time: Jun 18 2019 20:29:43
                      auto size-- 65535DDR cs0 size: 4096MB
                      DDR cs1 size: 0MB
                      DMC_DDR_CTRL: 0000002dDDR size: 3928MB
                      cs0 DataBus test pass
                      cs0 AddrBus test pass
                      non-sec scramble use zero key
                      ddr scramble enabled
                      100bdlr_step_size ps== 415
                      result report
                      boot times 0Enable ddr reg access
                      Load FIP HDR from SD, src: 0x00010200, des: 0x01700000, size: 0x00004000, part: 0
                      Load BL3X from SD, src: 0x00078200, des: 0x01768000, size: 0x000d0000, part: 0
                      bl2z: ptr: 05129330, size: 00001e40
                      0.0;M3 CHK:0;cm4_sp_mode 0
                      MVN_1=0x00000000
                      MVN_2=0x00000000
                      [Image: g12a_v1.1.3389-92241b5 2019-07-02 17:22:49 luan.yuan@droid15-sz]
                      OPS=0x10
                      ring efuse init
                      2b 0c 10 00 01 1b 2b 00 00 04 36 30 43 57 50 50
                      [0.017354 Inits done]
                      secure task start!
                      high task start!
                      low task start!
                      run into bl31
                      NOTICE: BL31: v1.3(release):4fc40b1
                      NOTICE: BL31: Built : 15:57:33, May 22 2019
                      NOTICE: BL31: G12A normal boot!
                      NOTICE: BL31: BL33 decompress pass
                      ERROR: Error initializing runtime service opteed_fast
                      U-Boot 2015.01 (Jan 13 2020 - 15:46:29)
                      DRAM: 3.8 GiB
                      Relocation Offset is: d6e50000
                      spi_post_bind(spifc): req_seq = 0
                      register usb cfg[0][1] = 00000000d7f3e500
                      NAND: get_sys_clk_rate_mtd() 290, clock setting 200!
                      couldn`t found selected chip: 0 ready
                      NAND device id: 0 0 0 0 0 0
                      No NAND device found!!!
                      nand init failed: -6
                      MMC: aml_priv->desc_buf = 0x00000000d3e40a70
                      aml_priv->desc_buf = 0x00000000d3e42db0
                      SDIO Port B: 0, SDIO Port C: 1
                      co-phase 0x2, tx-dly 0, clock 400000
                      emmc/sd response timeout, cmd8, status=0x1ff2800
                      emmc/sd response timeout, cmd55, status=0x1ff2800
                      MMC init failed
                      Using default environment
                      In: serial
                      Out: serial
                      Err: serial
                      reboot_mode=cold_boot
                      [store]To run cmd[emmc dtb_read 0x1000000 0x40000]
                      _dtb_init()-3446: mmc init failed
                      Amlogic multi-dtb tool
                      Cannot find legal dtb!
                      [store]Err:do_store_dtb_ops,L368:Fail in fdt check header
                      board_late_init(): [store dtb read $dtb_mem_addr] fail
                      load dtb to 1000000
                      [store]To run cmd[emmc dtb_read 1000000 0x40000]
                      board_late_init(): store dtb read 1000000 fail
                      [KM]Error:f[keymanage_dts_parse]L307:not a fdt at 0x0000000001000000
                      vpu: error: vpu: check dts: FDT_ERR_BADMAGIC, load default parameters
                      vpu: clk_level = 7
                      vpu: vpu_power_on
                      vpu: set clk: 666667000Hz, readback: 666666667Hz(0x100)
                      vpu: vpu_module_init_config
                      vpp: vpp_init
                      vpp: vpp osd2 matrix rgb2yuv..............
                      cvbs: cpuid:0x2b
                      card in
                      co-phase 0x2, tx-dly 0, clock 40000000
                      aml_sd_retry_refix[983]:delay = 0x0,gadjust =0x172000
                      [mmc_startup] mmc refix success
                      init_part() 282: PART_TYPE_DOS
                      [mmc_init] mmc init success
                      Device: SDIO Port B
                      Manufacturer ID: 74
                      OEM: 4a45
                      Tran Speed: 50000000
                      Rd Block Len: 512
                      SD version 3.0
                      High Capacity: Yes
                      Capacity: 14.7 GiB
                      mmc clock: 40000000
                      Bus Width: 4-bit
                      [MSG]ini sz 0x26cB
                      [fat]Filesize is 0x26cB[0M]
                      [fat]0x:leftSz 26c < BPS 2000, gotSz 26c
                      =========sdc_burn_paras=====>>>
                      [common]
                      erase_bootloader = 1
                      erase_flash = 1
                      reboot = 0x1
                      key_overwrite = 0x0
                      [burn_ex]
                      package = u218.VONTAR_X3_1000M_9.0.2020.01.13.15.46.img
                      media =
                      [burn_parts]
                      burn_num = 0
                      <<<<=====sdc_burn_paras======
                      [fat]Filesize is 0x73fc3580B[1855M]
                      [fat]0x:leftSz c40 < BPS 2000, gotSz 6c40
                      [MSG]image version [0x00000002]
                      [fat]Seek 0x1486f0 from 0x6c40
                      [MSG]itemSizeNotAligned 0x1910
                      [MSG]align 4 mmc read... [fat]0x:leftSz 1b6e < BPS 2000, gotSz 1347e
                      [MSG]Down(mem) part(dtb) sz(0x1347e) fmt(normal)
                      [MSG]Burn Start...
                      [MSG]load dt.img to 0x0000000001000000, sz=0x1347e
                      [MSG]Burn complete
                      Err imgread(L709):Logo header err.
                      Cannot find dev.
                      amlmmc cmd <NULL> failed
                      store - STORE sub-system
                      Usage:
                      store init flag
                      store read name addr off|partition size
                      read 'size' bytes starting at offset 'off'
                      to/from memory address 'addr', skipping bad blocks.
                      store write name addr off|partition size
                      write 'size' bytes starting at offset 'off'
                      store rom_write add off size.
                      write uboot to the boot device
                      store erase boot/data:
                      erase the area which is uboot or data
                      store erase partition <partition_name>:
                      erase the area which partition in u-boot
                      store erase dtb
                      store erase key
                      store disprotect key
                      store rom_protect on/off
                      store scrub off|partition size
                      scrub the area from offset and size
                      store dtb iread/read/write addr <size>
                      read/write dtb, size is optional
                      store key read/write addr <size>
                      read/write key, size is optional
                      store ddr_parameter read/write addr <size>
                      read/write ddr parameter, size is optional
                      store mbr addr
                      update mbr/partition table by dtb
                      [burnup]Err:store_read_ops,L84:cmd failed, ret=1, [store read logo 0x3720000 0x0 0x100000]
                      Err imgread(L447):Fail to read 0x100000B from part[logo] at offset 0
                      [MSG]Use upgrade res in pkg
                      [WRN]Can't find item [logo, aml_sdc_burn]
                      [MSG]logo for sdc UPGRADE[PARTITION]
                      [fat]Seek 0xbc37bc from 0x15bb6e
                      [MSG]itemSizeNotAligned 0x844
                      [MSG]align 4 mmc read... [fat]0x:leftSz 98c < BPS 2000, gotSz 16b1d0
                      [MSG]echo video prepare for upgrade
                      hpd_state=0
                      [OSD]load fb addr from dts:/meson-fb
                      [OSD]load fb addr from dts:/fb
                      [OSD]set initrd_high: 0x7f800000
                      [OSD]fb_addr for logo: 0x7f800000
                      [OSD]VPP_OFIFO_SIZE:0xfff01fff
                      [CANVAS]canvas init
                      [CANVAS]addr=0x7f800000 width=3840, height=2160
                      vpp: vpp_matrix_update: 2
                      cvbs performance type = 9, table = 0
                      cvbs_config_hdmipll_g12a
                      cvbs_set_vid2_clk
                      [OSD]osd_hw.free_dst_data: 0,719,0,575
                      [OSD]osd1_update_disp_freescale_enable
                      [MSG]dw,dh[1920, 1080]
                      [MSG]w,h[4,14]
                      [MSG]Exit before re-init
                      command: store exit
                      Single dtb detected
                      start dts,buffer=0000000001000000,dt_addr=00000000010000 00
                      get_partition_from_dts() 91: ret 0
                      Single dtb detected
                      parts: 17
                      00: logo 0000000000800000 1
                      01: recovery 0000000001800000 1
                      02: misc 0000000000800000 1
                      03: dtbo 0000000000800000 1
                      04: cri_data 0000000000800000 2
                      05: param 0000000001000000 2
                      06: boot 0000000001000000 1
                      set has_boot_slot = 0
                      07: rsv 0000000001000000 1
                      08: metadata 0000000001000000 1
                      09: vbmeta 0000000000200000 1
                      10: tee 0000000002000000 1
                      11: vendor 0000000014000000 1
                      12: odm 0000000008000000 1
                      13: system 0000000074000000 1
                      14: product 0000000008000000 1
                      15: cache 0000000046000000 2
                      16: data ffffffffffffffff 4
                      EMMC init failed
                      m3_nand_adjust_timing() sys_clk_rate 200, bus_c 6, bus_t 7
                      XXXXXXX======enter NAND boot======XXXXXX
                      sub cmd rom
                      new argv[1] rom_erase
                      do_rom_ops(): argc 2
                      arg 0: amlnf
                      arg 1: rom_erase
                      do_rom_ops() erase
                      <NULL>: MTD Erase failure: -30
                      No such device
                      no devices available
                      cmd [store init 3] init failed
                      ERR(../drivers/usb/gadget/v2_burning/v2_sdc_burn/optimus_sdc_burn.c)L683:Fail to init stoarge for sdc burn
                      Net: dwmac.ff3f0000amlkey_init() enter!
                      amlnf_key_read: ####
                      amlnf_key_read(): amlnf key not ready yet![EFUSE_MSG]keynum is 4
                      MACADDR:02:00:00:2b:1b:01(from chipid)
                      CONFIG_AVB2: null
                      Start read misc partition datas!
                      [burnup]Rd:Up sz 0x820 to align 0x1000
                      [store]Err:mtd_find_phy_off_by_lgc_off,L116:device(misc) is err
                      [store]Err:do_store_read,L1712:Fail in find phy addr by logic off (0x0),ret(1)
                      [burnup]Err:store_read_ops,L84:cmd failed, ret=1, [store read misc 0xd3e3f090 0x0 0x1000]
                      failed to store read misc.
                      info->magic =
                      info->version_major = 0
                      info->version_minor = 0
                      info->slots[0].priority = 0
                      info->slots[0].tries_remaining = 0
                      info->slots[0].successful_boot = 0
                      info->slots[1].priority = 0
                      info->slots[1].tries_remaining = 0
                      info->slots[1].successful_boot = 0
                      info->crc32 = 0
                      Magic is incorrect.
                      boot-info is invalid. Resetting.
                      save boot-info
                      info->magic =
                      info->version_major = 1
                      info->slots[0].priority = 15
                      info->slots[0].tries_remaining = 7
                      info->slots[1].priority = 14
                      info->slots[1].tries_remaining = 7
                      info->crc32 = -1075449479
                      [burnup]Wr:Up sz 0x820 to align 0x1000
                      [store]Err:do_store_write,L1828:Fail in find phy addr by logic off (0x0),ret(1)
                      nand cmd <NULL> failed
                      Usage:
                      store init flag
                      store erase dtb
                      store erase key
                      store mbr addr
                      [burnup]Err:store_write_ops,L148:cmd [store write misc 0xd3e3f090 0x0 0x1000] failed active slot = 0
                      wipe_data=successful
                      wipe_cache=successful
                      upgrade_step=0
                      reboot_mode:::: cold_boot
                      amlkey_init() 71: already init!
                      [KM]Error:f[key_manage_query_size]L515:key[usid] not programed yet
                      [KM]Error:f[key_manage_query_size]L515:key[mac] not programed yet
                      [KM]Error:f[key_manage_query_size]L515:key[deviceid] not programed yet
                      hpd_state=0
                      edid preferred_mode is <NULL>[0]
                      hdr mode is 0
                      dv mode is ver:0 len: 0
                      hdr10+ mode is 0
                      [OSD]VPP_OFIFO_SIZE:0xfff01000
                      [store]Err:mtd_find_phy_off_by_lgc_off,L116:device(logo) is err
                      [burnup]Err:store_read_ops,L84:cmd failed, ret=1, [store read logo 0x1080000 0x0 0x2000]
                      Err imgread(L537):Fail to read 0x2000B from part[logo] at offset 0
                      There is no valid bmp file at the given address
                      cvbs_set_vid2_clk
                      InUsbBurn
                      [MSG]sof
                      Set Addr 1
                      Get DT cfg
                      Get DT cfg
                      Get DT cfg
                      set CFG
                      Maybe with Erase all in Burn Card Maker??? I will try..
                        Im surprised this male to male USB cable isnt blowing peoples USB power driver on the laptop or PC
                        These TV boxes use a 2amp power supply so how is the male to male USB powering the device to be updated off a computer or laptop that doesnt even put out 2amp threw the USB port?
                        I would think that you could get it to recognize using the PC or laptop but then ide think it would need its own power to go any further
                        My first thought was at 7% thats when the device the tv box is connected to the USB driver is overheating and shutting down.
                          Thanks for helping me...
                            This is error at 7%....
                            SM1:BL:511f6b:81ca2f;FEAT:A0F83180:20282000;POC:F; RCY:0;EMMC:800;NAND:81;SD?:20000;USB:8;0.0;C
                            bl2_stage_init 0x01
                            bl2_stage_init 0x81
                            bl2_stage_init 0xc0
                            bl2_stage_init 0x02
                            L0:00000000
                            L1:00000703
                            L2:00008067
                            L3:15000020
                            S1:00000000
                            B2:20282000
                            B1:a0f83180
                            TE: 5671687
                            Board ID = 1
                            Set cpu clk to 24M
                            Set clk81 to 24M
                            DSU clk: 1200 Mhz
                            CPU clk: 1200 MHz
                            Set clk81 to 166.6M
                            board id: 1
                            DATA transfer complete...
                            fw parse done
                            AML DDR FW load done
                            PIEI prepare done
                            DDR3 probe
                            ddr clk to 672MHz
                            dmc_version 0001
                            Check phy result
                            ddr probe id done
                            fw parse done
                            PIEI prepare done
                            DDR3 probe
                            ddr clk to 672MHz
                            dmc_version 0001
                            Check phy result
                            1D init succeed
                            need_2d=0, skip 2d fw load...
                            ddr init done, boot next stage
                            result report
                            DDR cs1 size: 0MB
                            Data req end
                            RUN bl2 usb boot
                            MVN_1=0x00000000
                            MVN_2=0x00000000
                            OPS=0x10
                            ring efuse init
                            [0.017319 Inits done]
                            secure task start!
                            high task start!
                            low task start!
                            run into bl31
                            U-Boot 2015.01 (Nov 23 2019 - 15:15:05)
                            DRAM: 3.8 GiB
                            [MSG]MMC init in usb
                            InUsbBurn
                            [MSG]sof
                            Set Addr 1
                            Get DT cfg
                            Get DT cfg
                            Get DT cfg
                            set CFG
                            ID[16]
                            tplcmd[ echo 12345]
                            12345
                            [MSG]ret = 0
                            [info]success
                            BULKcmd[ low_power]
                            [info]success
                            ID[16]
                            tplcmd[ download mem dtb normal 78980]
                            [MSG]Down(mem) part(dtb) sz(0x13484) fmt(normal)
                            [MSG]totalSlotNum = 0, nextWriteBackSlot 2
                            [info]success
                            [MSG]Burn Start...
                            [MSG]load dt.img to 0x0000000001000000, sz=0x13484
                            [MSG]Burn complete
                            BULKcmd[download get_status]
                            [info]success
                            BULKcmd[disk_initial 1]
                            Single dtb detected
                            Single dtb detected
                            parts: 17
                            EMMC init failed
                            NAND device id: 0 ff ff ff ff ff
                            NAND init failed
                            device_boot_flag=2
                            [store]ERR:FAILED in get_device_boot_flag
                            [info]failed:
                            What this means?
                              If I were you I would insist in the method of "shorting pins". Sometimes it may take a few tries to succed and with different parameters and combinations (normal erase or full erase, different USB ports of the box or PC, different ROMs for DDR3 or DDR4 etc).
                              On the other hand you can try to boot your box with coreelec 9.2.2 (it supports S905X3). You can burn it in an SD card, choose the right dtb file and rename it to dtb.img (probably the generic for your box and memory). Of course it will not fix your problem but you will test if your box boots at least with it (of course in that case you can use KODI as usual). The box always tries to start from sd.
