mk808b and 3D performance
    Hello everybody,
    I have a question to which I couldn't find any answer in this forum yet. (If I overlooked it, I'd be happy to be pointed to the correct thread.)
    In another thread, I also asked about 3D performance (referring to AnTuTu). Everybody was benchmarking it with receiving framerates of 25fps and higher, while I am stuck around 7 fps for AnTuTu's "epic citadel" benchmark animation. I tried several suggestions (removing SD-card or keyboard while benchmark, attaching a second power supply, tweaking CPU speed with "rom tools", etc.) but nothing has worked so far, I am always stuck and those horrible framerates.
    I have also tried that with different roms (digitop, Finless, etc.), but nothing changes. What got me curious now, that a friend of mine (with a mk809-ii) received the same low framerates. So maybe, I am just missing out some settings to "activate" 3D acceleration? Does anybody know and is willing to tell me, if I have to change some regular settings to make full use of my mk808b's powers? I checked the settings and have left all rendering and GPU settings at default values (since I have to admit I am not quite sure what to do about them). Is there anything I need to change? Any help would be greatly appreciated.
    Thank you guys for this excellent forum. I am quite content (apart from the benchmarked fps) with my mk808b, and to a large extent this is thanks to the help from this forums members. So, thank you all very much, to anybody helping out here!
    Originally posted by 1234klaus View Post
    Hello everybody,
    I know some of the settings in the development section in settings can have detrimental performance to GPU rendering - you won't need to activate anything for 3D performance.
    Antutu do a 3D benchmarking program called 3DRating for OpenGL ES 2.0 - Download it and report back your score.
    Currently Using:
    2 x Nvidia Shield TV | MiniMX III
    Retired Devices:
    MiniMX III-II | Mk808b Pro | Mk808b Plus | Raspberry Pi 1 + 2 | UBOX R89 | MK808 | MK808b | CS008 | X1 4K (rk3288_809) | CYX_809III | Ouya | CX-919 | S82 Plus | Tronstmart R68
      I think you are mixing up something here.
      AnTuTu and Epic Citadel are two different benchmark apps. On the 3D part of AnTuTu a value of around 10 fps is perfectly normal for a mk808b. On Epic Citadel, you should get a value of 25-30 for a stock rom.
      Here are the links to the Apps on Play Store:
      AnTuTu
      Epic Citadel
        Thank you very much for your concern. I installed this 3D benchmark app, but I cannot start it. It launches and the START and EXIT buttons appear, but I can't click either of them. That's so weird. I am running "MK808b digitop mod MINIX NEO G4 port". Maybe I should switch back to finless 2.1?
        AnTuTu
        Epic Citadel
        Thanks again, phinc, for clearing that out. I feel really stupid I had no idea, and I was already about giving up hope. So, thanks for the clarification. I will give the "REAL" citadel a try now.
        Edit: I just tried it and that benchmark gave me a score of 31 fps average. Sorry for bothering you guys. But thanks to you, I feel really relieved now.
