My MXQ-4K TV Box is bricked (the red led thing). Please I need some help finding the right firmware for the following board:
I downloaded (mxq-4k)_1G8G_rtl8189_20171113_r1-android-6, then successfully "burn" the firmware to the SD using Rockchip Create Upgrade Disk Tool v1.53.
Once I found which pins I have to bridge, the tvbox boots in recovery mode and then it freezes saying it cannot mount SD card.
I read somewhere it might be the wrong firmware for the chipsets. Looks like every MXQ is not built with the same components (amlogic or rockchip?).
By the way, it is the MXQ 4K black, not PRO.
