X88 KING. NEW OFFICIAL FIRMWARE UPDATE 20200424
    Yesterday I got via OTA the official firmware update 20200424 and
    now google voice assistant works. I use the MX3 remote and voice assistant works fine.
    I get lower cpu temps and shorter loading time.
    If anyone finds the change log for this new firmware update, please share it here.
    Also if anyone can share a link to this firmware update as zip it would be nice.
    I tried to find the OTA update file but all OTA folders are empty after the update. Maybe they get cleaned after applying the update. If anybody could check if the update is in OTA folder before applying the update and share the file it would be awesome.
      Cannot find the image file
        Can't find the file
          Hello I need firmware as IMG for x88 king please help me
              Does anyone have x88 King firmware they can share? Can't find it anywhere.
                X88 King Android 9.0 TV BOX S922X Hexa-core Mali-G52 MP6 LPDDR4 4GB 128GB Set Top Box Dual Wifi Bluetooth 5.0 1000M LAN Player https://i.imgur.com/DJ0O9iM.png https://i.imgur.com/yEvWKC4.png https://i.imgur.com/Ohcf0Bn.png
