mxq ERROR 0X10105002
    hello i new here and i have a problem
    afew years a try to update my mxq box and i brick it
    today i try to undrick the box, but i have some problems
    i download the usb burning tool 2.1.7.1
    i download a few img some give a error other ones bloc at 2% whit the code 0x10105002
    i try to connect afert the start
    i try a older version of usb burning tool
    try various img
    try diferente usb cable
    try diferent windows (7 and 8,1)
    nothing any ideas????
    Y U WRITE IN CAPS?
    select FULL ERASE
      for no reason was activate
      full erase?
        done
          Does it work?
            blue ligth but no image
              help???
                Throw it in the trash.
                  Uncheck "erase bootloader"
                    all ready do that
