I have broken TX2 that I wanted to reload the firmware, but the Android Tool giving me No Device Found even when I follow the instructions to connect the box to my pc using USB cable and pressing the reset, button, the sw Android Tool doesnt see the box, so is it a USB driver or something else.
Your help is appreciated, thanks in advance.
Note: I found the solution by installing a driver.
