Firmeware Upgrade / Custom Rom for Renkforce 4K XBMC Android TV Box
Hello, I've the Android TV Box "Renkforce 4K XBMC Android TV Box Android Mini PC (A764) 4 x 1.8 GHz 2 GB Androidâ„¢ 4.4" I'm looking for a firmeware upgrade and custom rom for this device. It works with a Rockchip RK3288. I found an article (android-nougat-7-1-2-beta-release-for-ugoos-ut3-ut3s-um3) about devices that works also with the same chip. Can I use this firmeware also for my device? Where can I find furthermore firmeware and custom roms that fits in my case? Thanks in advance.Tags: None
No custom firmware exists for this device.
You also can't use other devices' firmware for it since it will brick your device.
You have to look for devices with custom firmwares and updates before you buy a device, research a company's past support, since custom firmwares won't appear out of nowhere for discontinued devices no one has.
There are currently 2363 users online. 0 members and 2363 guests.
