[solved] ADB error: device not found
    Hello,
    I've a problem with the ADB.
    I've installed the "Rockchip_Driver Rockusb_v3.5 " from Tronsmart
    I've these settings in android
    Settings -> [DEVICE] USB -> Enable Connect to PC
    Settings -> [PERSONAL] Security -> Enable Unknown Sources
    Settings -> [SYSTEM] Developer options -> Enable USB debugging
    K-R42 clone
    press and hold little restore button on which is under device
    In the devicemanager (XP SP3) I see
    - Class for rockusb device
    --- Rockusb Device
    RKBatchTool_v1.7 (by lewy20041) recognize the device at [1] (green 2-1-1)
    RKAndroidToolv137 (by MK908 4.2.2 Finless 1.5) recognize the device (Found RKAndroid Loader Rock Usb)
    BUT
    adb shell
    * daemon not running. starting it now on port 5037 *
    * daemon started successfully *
    adb shell
    What's wrong?
    What can I do?
    Greetings
    RK3288 Devices
    - Overview BOX (LINK !)
    It's creasy ... really creasy...
    I try to install the USB-Drivers (not the classdriver) for the "Android Composite ADB Interface (Google, Inc.; 06.12.2010; 4.0.0.0)" along the hole day...
    Restoring often an 18GB acronis image of my system-partition...
    Trying different solutions (Moborobo, PdaNet, UniversalAdbDriverSetup6.msi,... and a different HW (USB 3.0 ExpressCard with Renesas(NEC) ChipSet)) and suddenly the installation with Moborobo with the onboard USB2.0 at my NB is working!?!?
    BTW: Moborobo needs internet connection to install driver AND keeps USB-drivers after uninstall
    One of my different ADB-versions doesn't work, but the version from the "TPSarky-VonDroid-Root.rar" and the version from neomode works via "Android Composite ADB Interface" if the Box starts normal...
    Greetings...
    RK3288 Devices
      Thank you very much. Moborobo really saves my time in setting up my Pipo M7Pro. It works like a charm, thanks again~~
