[ROM] Spartan_ROM ATV S922X
Hi, how can I replace the Leanback keyboard?
I have an air mouse but the new leanback keyboard only accepts input from the dpad, I would still like to type with the virtual on-screen keyboard with the air mouse.
When I install AOSP keyboard it installs fine but the keyboard does not appear on the screen and I have activated the keyboard in the settings.
Can someone please point me in the right direction?
Excelent ROM btw, the only ROM where I don't have any issues with 4k 60hz resolution, thank you!
Originally posted by badboyswa View PostHi, how can I replace the Leanback keyboard?
Originally posted by hman89 View PostIs there possible that you will add some more 922X boxes for Spartan Rom? I'm using now Magicsee N6 Plus box. Its really good box, but have just few firmwares - stock and one custom. I can be your beta tester for this box if you want.
Originally posted by Ac2n View PostHi, I try Spartan V5 and it's work very well, but I have a problem with Amazon Prime Video downloaded from Google playstore, installation and configuration OK but when I try to play a video there is an error, and can't play nothing... What the problem ?
Edit : I'm in France
Originally posted by minixfreak View Post
you have to download the mobile version as the device is not certified , its like netflix u have to download mobile version
All went well.
"Please wait..." is that TV checks update info.
After a while, it will go to main screen.
Thanks for your efforer.
@minixfreak
Spartan Rom was installed by USB-Maker method, because my windows PC can not keep recognzing the USB device.
After rebooting and updateing, Red Spartan Screen showed, and I set the language as "Chinese Simplied", as the pic below.
Then Screen "Please wait..." kept and no more progress.
Did it fail?
Or does it keep visiting internet? Some websites can not be visited in China.
Would you please help me out?
There are currently 1440 users online. 1 members and 1439 guests.
