anyone knows?
box with best audio codec support
Originally posted by ministerjee View PostWithout buying nvidia shield tv or using coreElec , is there any box that will support all newer audio codecs, i.e dolby atmos/DD+/DTS HD-MA 5.1??? or may be passthru using kodi??
anyone knows?
Hi Mo
as always quick with response..i have am6 plus running stock..but want another cheap box that will support all codecs from android , as i got a new avr that supports newer codecs dolby atmos etc..so i was thinking of getting the cube x3 pro. want something with newer SOC , what box do u recommend and what rom you recommend?
Ugoos X2 Cube, AM6 S922x and all Android ROM's I make(Rockchip ones) support HD Audio passthough in Android.
It runs the same firmware and improvements as the AM6 so should be familiar.
You can then use the 0.3.2 dual-boot ROM.
thanks mo123 , i will get the ugoos X3 pro , and try the dual boot firmware..by the way do u have a custom rom for x3?
The X3 Cube is the only S905X3 that supports HD Audio, so go with it if you want.
Originally posted by ministerjee View Postthanks mo123 , i will get the ugoos X3 pro , and try the dual boot firmware..by the way do u have a custom rom for x3?
There are currently 1516 users online. 1 members and 1515 guests.
