[ROM Image Firmware] ANDROID TV Telesystem UP 4K S905D BETATESTING
    This rom is a version Android TV for Telesystem UP 4K S905D, however the digital receiver should be not work
    I haven t the box but the rom should work well because i m started from original rom of Telesystem that has a S905D Amlogic - very similar to S905W except for digital integrated DVB receiver - and i have make some modifications to system and boot to make it working with Telesystem UP 4K box and maybe with other box S905D. To insure the maximum compatibility i have realized two version of rom, one with stock boot and another with modified boot, please test the second if the first not work. The instructions are in the zip file that must be decompressed and the roms can be flashed with USB BURNING TOOL
    LINK ROMS ANDROID TV
    If anything goes wrong don t worry! You can restore the stock rom always by USB BURNING TOOL downloading it from this LINK
