[ROM] [S905X] Android TV Custom Rom 7.1.2 Universal (Most S905X) (MXQ pro 4K 1/8GB ect...)
    Download NEW V7.4 (24/Oct/2020)
    Download: https://bit.ly/aidanscustrom
    This is my version 7 Rom I use this as a daily driver and it is stable and Lag free
    Works well on 1GB Ram boxes
    Disney+ sound now works in v7.2 (Tested in v1.9.1)
    Improvements Made
    NO LAG!
    No longer based on atvXperience
    User Interface renders at full 1080p
    Fixed bug where remote power button would turn box off/standby but not wake it up again
    Added Miracast (scren mirroring)
    Removed Chromecast and other bloat (wont work in uncertified devices and would fill storage in 24 hours)
    New bootlogo and boot animation (No longer will bootanimation appear frozen during 1st boot)
    Bluetooth disabled (I can re add bluetooth functonality if someone needs it)
    Misc tweaks & adjustments
    New Update available
    Improvements [V7.4] (24/10/2020)
    PRE ROOTED! (Root switch does not work, Always ON)
    Disney+ now has working sound (v7.2 but worth mentioning again)
    All preinstalled apps can be Un installed (exept system apps)
    Samba MSWindows File Server [NAS] (Usb HDD, SD, Internal)
    Google Documents UI added (fixes bugs in some apps opening files)
    Stock Downloads File Explorer Added (Related to documentsUI)
    Google Assistant Text Search Navigation Bug
    Phone Settings crash fixed
    Wi-Fi Tethering now works (Ethernet to Wi-Fi)
    Changed Mouse cursor
    Certificate installer fixed
    GlobalKeyInterceptor added
    OneTimeInitaliser added
    GooglePartnerSetup added
    Updated Backdrop (no longer claims chromecast built in)
    Alternative Screensaver Included (Can uninstall)
    Reboot to recovery option in all apps section
    More visual tweaks
    More Performance tweaks
    WiFi Fix
    Download v7.4: https://bit.ly/aidanscustrom
    Im very happy with how this turned out, please install and let me know if it works for you have any suggestion
    Tested on
    MXQ Pro 4K (1/8GB P212)
    Many More Devices (95% of s905x)
    Install using amlogic burn tool
    Download Burn Tool: https://bit.ly/aidanscustrom
    More Details on XDA & The Website
    NEW VERSION 7
      It seems pretty cool! Amazing work, but sadly it gives me Uboot/Get result/DiskInitial error :/. Can you add support for my mxqpro 4x? need a working firmware for this? I have this one.
      I would appreciate it
        yes i will try and take the files from the ROM you sent link for there is so many variation of the MXQ pro 4k as this rom will boot on mine
          Thanks! I will wait for any news
            hey sorry bricked my test box during testing, just sorted tonight so hopefully get a upload tomorrow
              you tried, that's what it's worth, hope u can fix it!
                Click image for larger version  Name:	2020-06-09_13-09-41.jpg Views:	124 Size:	110.7 KB ID:	807634
                  Ive tried thar ROM, works ok on my 2GB box (No wifi for me) but is very laggy on my 1GB box
                  And this is not the place for recommendations THIS IS A ROM LISTING NOT A "RECOMMEND ROMS" or a "HELP BRICKED"post
                  START YOUER OWN THREAD
                    Hi ,
                    so you mean the Post of User "Jemvud" ???
                    greetings / gefattern
                      Hi ,
                      Yhea sorry just thought this wasn't place to put it
                        Hi ,
                        i already contacted him , if it is another Rom then it is better to make a new informativ Rom Thread ,
                        i wait for his answer then we go on , i delete it , if it is a different Rom , then he better can make a own
                        Rom Info Thread for Box .... , so more Users can find , be patient , no Problem ,
                          Hi ,
                          ok thank you yhea thought that woud be better,
                            v7.1 https://youtu.be/aYawxHBVir8
                              Improvements [V7.3] (06/10/2020)
                              Download: https://www.youtube.com/watch?v=0uci6Rl70t4
                              More visual tweaks
