This is my first Android TV stick and I'm seeking your help.
I want to install CWM on my UG007-II and so far I have been unsuccessful.
When I first purchased my UG007-II, it had Android v4.1.1 on it. I rooted it successfully using the TPSarky-VonDroid-Root method. I then successfully installed CWM by downloading the UG007 CWM zip file, placing it at the root of my microSD card, and just booting up the stick. When asked to install the update, I clicked yes. The stick rebooted automatically into CWM, I made my Nandroid, rebooted back into the Homescreen, and all was well.
Just 2 days ago, I flashed the UG007-II with the official UGOOS v4.2.2. Jellybean update.
I rooted it just fine using the TPSarky method but I was NOT able to install CWM the same way.
Once I install the CWM zip file, the stick will reboot automatically into CWM but I can't create any Nandroids and when I reboot the stick, it doesn't go to the Homescreen anymore. It just keeps rebooting back into CWM.
To fix this issue, I had to flash the v4.2.2 update file again.
Any suggestions/help/links?
TIA,
Optimummind (David)
