Xiaomi Mi TV Stick
Google Assistant Official International Version 4K HDR Netflix
Android 9.0 2GB RAM + 8GB ROM
Main Features: as found
? Android 9.0 Version
Based on the Android 9.0 OS, with fast speed and smooth performance, which is designed to turn your regular TV into a smart one.
? DDR4 2GB RAM, eMMC 8GB ROM
It is configured with DDR3 2GB RAM, and eMMC 8GB ROM, thus it can provide enough room and freedom to install Apps without worrying about running out of space.
? DTS-HD and Dolby Stereo Sound
Processed by Dolby audio and DTS-HD audio encoding, let you fully enjoy the 3D premium sound quality and cinema effect at the same time.
? HDMI 2.0 Connector
You can go directly to let your TV and Mi Box S connect through an HDMI cable and set up your home cinema for the best 4K x 2K UHD multimedia experience.
? High Clarity 4K HDR
Features the latest 4K HDR technology and high-speed 4K processing, up to 60fps playback, giving ultra high-definition and lifelike visual experience.
? Access Tons of Content
Compatible with various apps, giving you access to tons of superior video, services and a constant stream of fresh new content.
Specifications:
- Android 9.0 operation system
- Amlogic S905 Y2 Cortex A53 CPU, quad-core
- ARM Mali-G31 MP2 GPU
- 2.4GHz + 5.8GHz dual-band WiFi
- 2GB RAM + 8GB ROM Specification
Brand: Xiaomi Model: MI Type: TV Dongle GPU: Mali-G31 CPU: Amlogic S905 Y2 Core: Quad Core RAM Type: DDR4 ROM: 2G ROM Color: Black |
Decoder Format: H.263,H.264,H.265,HD MPEG4 Video format: 1080P,4K,4K x 2K,AVS,H.264,H.265,ISO,MKV,MOV,MP4,MPEG-1,MPEG-4,MPEG1,MPEG2,VC-1,WMV Audio format: AAC,FLAC,MP3,OGG,RM,WMA Photo Format: BMP,GIF,HD JPEG,JPEG,PNG,TIFF Support 5.1 Surround Sound Output: Yes |
5G WiFi: Yes WIFI: 802.11 a/b/g/n/ac Bluetooth: Bluetooth 4.2 Power Supply: USB Port Interface: HDMI,OTG,Type-C,USB3.0 Languages: Multi-language Language: Multi-language HDMI Version: 2.0 Other Functions: Others HDMI Function: HDCP Power Consumption.: 5W |
Power Type: Digital Power Supply Power Input Vol: 5V Power Adapter Input: 100-240V / 50-60Hz |
Product weight: 0.0850 kg Package weight: 0.1850 kg Product size (L x W x H): 9.50 x 3.50 x 2.00 cm / 3.74 x 1.38 x 0.79 inches Package size (L x W x H): 14.50 x 7.50 x 3.50 cm / 5.71 x 2.95 x 1.38 inches |
Package Contents: 1 x Mi TV Stick, 1 x HDMI Cable, 1 x English Manual |
Gearbest
