Using the RKAndroidTool.exe included in your BETA1 package, I followed the simple instructions and the installation worked perfectly.
BT seemed very solid... I paired a Moga BT gamepad ( http://www.amazon.com/gp/product/B00...s2&tag=usdk-20 ) and installed Riptide GP ( https://play.google.com/store/apps/d...nit.blue&hl=en ) and then my son and I played continuously for a couple hours without any loss of BT connectivity, while sitting about 12 feet from the Imito QX2.
During some later testing I found that the wifi connection was lost for no obvious reason, though it seemed to happen immediately after I attached a USB flash drive with movies for movie and video testing. I had difficulty reestablishing the wifi connection until I stopped/started wifi.. Afterwards it has seemed to stay connected.
I installed MX Player and attempted playback of a variety of movies, some HD video from my Canon DSLR as well as some Blueray and DVD rips. Mostly movie playback worked well... During a few of the movies from my DSLR there was a bit of stuttering, and the playback of a DVD rip of an action anime seemed slight less than perfectly smooth- at a point when there was a lot of action.
I'll continue to play with the BETA and report what I find. I am liking it much better so far (mostly because my BT is working now).
Thanks so much for your help.
Tom
