Enjoy and stay safe
[ROM] H9 X3 Original Firmware Link
Guest
soldiaz ...I like the features that the H9-X3 has, but its a little buggy, I hope that a newer firmware will come out for it.....However I have a X96S and have put the SlimBox rom Version 9 on It, and seen that the
rom will work on the H9-X3 box...so if I decide to flash it I will use the slimbox rom on it. Maybe you should think of trying this one.I like the SlimBox rom, its almost like the nvidia shields.
Originally posted by soldiaz View PostAny information about wifi? Is it really AC (1.300 Mbit/s)....I ordered but did not receive yet
Originally posted by masher17 View Postsoldiaz ...I like the features that the H9-X3 has, but its a little buggy, I hope that a newer firmware will come out for it.....However I have a X96S and have put the SlimBox rom Version 9 on It, and seen that the
Yeah slimbox sounds really awesome...but minixfreak "based" os has best wifi throughoutput....the H9x3 has 2 internal antennas?
Originally posted by RiCkLaR_atvX View Post
What that is a ridiculous number, AC 5GHz WiFi max throughput is around 867 Mbps, so maybe seller is trying to combine the the 5GHz and 2.4GHz values for marketing purposes but that is not realistic real-world usage.
In case of brick: https://forum.freaktab.com/filedata/fetch?id=810457
RiCkLaR_atvX which rom you recommend for crossflash?
Guess the 96 max + does not have wifi ac...does the transpeed have?
Most important thing to do is update your home network, if you haven't upgraded to AX-band WiFi-6 router you are missing out; had an ASUS_AC-gaming router that I replaced with just a standard TP-Link WiFi-6 (AX) router and both the 2.4 GHz and 5.8 GHz signals are stronger then the super expensive gaming router. I don't trust ISP routers so I always use my own WiFi-router plugged into the ISP router and disable WiFi on the ISP's router.
There are currently 2876 users online. 0 members and 2876 guests.
