CHUWI LarkBox Portable World's Smallest 4K Mini PC
    6GB LPDDR4 + 128GB ROM 2.4GHz + 5GHz Dual Band WiFi 1000Mbps BT5.0
    Support Windows 10 - Black 6GB LPDDR4 + 128GB ROM EU Plug
    Information as Found:
    CHUWI LarkBox Mini PC, World's Smallest 4K Mini PC the latest 4K Mini PC in the world, is equipped with the chipset Intel Celeron Gemini-Lake N4100 CPU, which provides you with a smooth experience of watching videos or playing games through the USB 3.0 port, making the transmission speed faster than before. Its faster speed provides you with higher work efficiency. On the other hand, LarkBox is also the best choice for your home entertainment. Equipped with a silent cooling fan, the heat in the compact body can also be fully released, so that the performance of the host is more stable, smooth decoding of 4K video, creating an immersive living room audio and video experience, you can Let the family play games or watch TV programs together, the best choice for family party video playback
    Main Features:
    Ultra-small body, only apple size: 61 * 61 * 43mm volume, easy to grasp with one hand, ultra-portable
    Powerful Intel Celeron Gemini-Lake N4100 processor: efficient and continuous performance output, improve office and learning efficiency
    Stunning 4K experience: UHD Graphics 600 graphics card, smooth and hard decoding 4K video,
    Creating an immersive living room audio and video experience
    6GB + 128GB: 6GB LPDDR4 memory, fast multitasking in the background, 128GB large storage support capacity expansion,
    Support 2TB SSD hard disk expansion
    Perfect interface ecology: USB-A * 2, Type-C, HDMI, 3.5mm headphone jacks are all available,
    Supporting Bluetooth 5.0 wireless connection to more peripherals
    Active heat dissipation: equipped with a silent heat dissipation fan, the heat in the compact body can be fully released,
    So that the performance of the host is more stable
    Gearbest
