Unofficial Android TV ROM for S812 BCM4335
    Suitable for M8S M10 or any tv box with 2GB RAM S812 and BCM4335 chipset ( M8 v8_8 board)
    What you gets :
    Android 5.1
    Google Android TV experience
    DISCLAIMER
    I am not responsible for bricked devices and any other problems caused after flashing this rom.
    So,think carefully before flashing this rom and flash at your own risk.
    BASED ON
    Leelbox M9S kernel
    mini M9S tv stock system by Guest danz
    Modified Nexus Player Build.prop
    Amlogic S812 boot logo
    Marshmellow bootanimation
    What are working :
    2GB RAM ( Yeaaaaaaaaaa BOIIIIIIIIII without KERNEL PANIC)
    WiFi works ( 5.8ghz and 2.4ghz )
    Bluetooth works
    Ethernet works
    Leanback launcher works
    Backdrop Daydream works
    Just like a normal firmware
    Known bugs
    Couldn't sign in Google account
    Netflix Error UI 800-3
    Resolution can't be changed to 4K
    Youtube TV 1080P 60 video shuttering ( 1080p 30 works )
    Mediashell a.k.a (Chromecast built-in) wont work
    Waiting for you to figure out
    DOWNLOAD LINKS
    S812 ATV.zip
    https://mega.nz/file/aBIHAChY#CxOn9c...q1DHlEulZyBXzo
    OpenGappsTvSTOCK.zip
    https://mega.nz/file/OFAhkKjL#hgijIY...X1W6JQmGuCEj-Q
    SYSTEM FILES for ROM DEVELOPERS
    https://mega.nz/file/qVRRWAAT#g-84hb...78WuFDwGXbJj3w
    TUTORIAL for flashing the rom
    1) Download and install your device Twrp recovery ( Recommend TWRP from abdul_pt)
    https://forum.freaktab.com/forum/tv-...mlogic-devices
    2) Backup your current ROM using TWRP unless anything happens
    3) Wipe all
    4) Install S812 ATV.zip
    5) Reboot system
    6) After reaching the Leanback Launcher , restart the tv box into recovery again
    7) Install OpenGappsTvSTOCK.zip
    8) Reboot system
    THAT'S ALL
    IMPORTANTS
    My custom rom still unstable and sometimes UNFORTUNATELY...................... has stopped happens.
    SetupWraith.apk deleted because it stuck at Connecting To Google.
    I hope that any ROM Developers can help to complete this firmware.
    SYSTEMS FILES will uploaded
    Thanks Guest danz abdul_pt mo123 for providing and developing ROMS RECOVERY and HELPS
    CREDITS goes to
    Leelbox
    The Pure Nexus Project
    I am a newbie here and also a student which have zero experience for developing custom rom.
    SO........................
    Any problems
    #TagFreakTabProDevelopersForHelps
    Good job, I thought no one would do anything else for this box!
    Maybe I will try to apply it in my box, although the sight has a RTL8723bs chip
      Anyone tested this rom? Thanks
        What you gets :
        Android 5.1
        DISCLAIMER
        BASED ON
        Leelbox M9S kernel
        What are working :
        Bluetooth works
        Ethernet works
        Known bugs
        DOWNLOAD LINKS
        S812 ATV.zip
        3) Wipe all
        5) Reboot system
        8) Reboot system
        THAT'S ALL
        IMPORTANTS
        CREDITS goes to
        Leelbox
        Any problems
        Click image for larger version  Name:	Screenshot_2020-05-26-12-04-51.png Views:	74 Size:	219.9 KB ID:	806547
        Any more updates or feedback to this rom? Thanks
          Not really an update but I installed this on my OTT M8S S812 box and just about everything works. Only real issues I have seen is that the Lan connection speed is slow, and Google Play Store Opens but you can't search for anything. Other than that, this is actually the best 5.1 Android TV rom I have ever used. Even Recommendations on the Home Screen are working. which is really a surprise. If I could fix the Google Play Store problem this would be the best lollipop firmware i have ever tried for this box.
            M8S+ AP6330 S812 ?
              Anyone knows where I can get the TWRP file? The Link to Abdul's files do not work anymore. I am looking for TWRP for M8S ott. Thanks in advance
                after a long time I decided to use the box and replace notouchdelegate to the version of the r-box atv experience from the freaktab forum and after updating gaps the google account worked
                  Updating the new link for whom need
