remote control power button
    I have a Gobox x1 s805, a put the minix rom and works great,
    So 1 have a problem with all the remote.conf, that i use.I Tried 2 differents remote.conf and both has the same problem, the remote control turn off the box, but not turn on the box just turn on with the control. MXQ
    any ideas to solve ?
    Originally posted by status_38 View Post
    Power on key is defined in bootloader, get the ROM .img you want to use, open it in Amlogic Customization Tool > Check Replace Kernel/U-boot and replace all u-boot files with files from your STOCK ROM. (when you open an .img check tmp directoru in amlogic tools path for these files). Don't touch anything else.
      Thank you ever so much. That worked perfectly
