Anyone try/experiment with Xbox 360 Wireless Controller for Windows?
Here's a video (I don't know for sure if ti'll work becouse I don't have a xbox controller so I haven''t tried it yet and this video was made for android 3.1 HONEYCOMB, but you should give it a try)
How to Connect Wireless XBOX 360 Controller to Android Honeycomb 3.1 - YouTube"Success is a lousy teacher. It seduces smart people into thinking they can't lose."
- Bill gates
Hello
I use an xbox 360 controller windows version
and it works fine with Finless 1.7 ROM
if you want to use it to play games with. I can only recommend that you install the USB / BT Joystick Center from google play
it takes some time to set up, but work just fine
I have played and tested these games :
Asphalt 8
Modern combat 4
Frontline commando
T-J@Y
Asphalt 8
Modern combat 4
Frontline commando
T-J@Y
There are currently 2876 users online. 0 members and 2876 guests.
